Crashes with VDJ7 cues [fixed]
I am running Virtual DJ 7 along with the Showxpress 8.2.18 and the plugin on windows 10.
Everything was working fine, but now when VDJ hits a cue for a light scene Showxpress crashes on cue (no pun intended).
Is anyone else having or had this problem? I have done searches in the forum and only find Mac related problem.
Re: Showxpress crashes with VDJ7 cues
I found the problem after I tried running another lighting scene and found that it worked fine with the other scene. Turns out the one scene was corrupted some how and I just had to rebuild that scene.
Re: Crashes with VDJ7 cues [fixed]
Also found out that you can not name a button with just a number like "22". You need to add a letter to the number like so "22A or 22 A".
