Controlling via MIDI track in Logic Pro?
Postby Ghostfeeder » 24 May 2018, 00:00
Hey,
I've searched and searched and can't quite get a clear answer on this one:
Is it possible to use Logic Pro X to play my backing track along with a MIDI track that runs my light show? The past few years I have been using the timeline and WAV files, but the issue of the lights being half a second out of sync here and there has been hard to work around. I'm assuming that MIDI would be more accurate.
I'm looking for a more efficient solution, like how you can treat DMXIS as a plug-in in Logic or Ableton or whatever and run it off a MIDI track on the timeline in the DAW. Can that be done with ShowXPress?
Can anyone help?
Thanks!
Ghostfeeder
Re: Controlling via MIDI track in Logic Pro?
Postby support » 24 May 2018, 07:19
You can simply send midi notes to trigger buttons in the tab "Live > Buttons".
This gives an accurate sync.
FYI: https://forum.thelightingcontroller.com/viewt ... =76&t=5344
Return to Midi
