No Output from ShowExpress 1024
Postby Redsand187 » 06 November 2023, 02:02
I built a timeline for a halloween show. However, when I went to use it, it would not output the DMX no matter what I tried.
Version 9.2.38, ShowExpress 1024, MacOS, 18 fixtures 4 channels each, 4 channels apart, , DMX turned on, 3dViewer showing simulation, video playing. (Also, the 3dViewer isn't centered, most of the window black and my stage is in the bottom corner :?: )
No matter what I try it will not output to the fixtures. I did try a single fixture on a new project just turning on and off, that worked. So I assume the interface is good.
Is there something I am missing?
Redsand187
Re: No Output from ShowExpress 1024
Postby butlerray » 06 November 2023, 12:49
Did you check that the DMX button was switched on. It's beside the 3D viewer button.
I've also had to change the dmx cable a few times.
ray
butlerray
Postby support » 08 November 2023, 08:29
The USB LED (the green one) of our DMX interface blinks slowly with our software connected and no light scene running.
It blinks faster when a light scene is running.
Please confirm you see that.
The "not centered 3D view" problem is fixed in the curent version of our software (V9.3.8).
FYI: https://thelightingcontroller.com/viewt ... 9&start=30
Return to Live - TimeLine
