stream deck xl
stream deck xl
Postby stef » 24 March 2024, 10:21
Hi dear,
Work the software in the live buttons with the elgato streamdeck xl?
stef
Re: stream deck xl
Postby support » 24 March 2024, 16:07
We found only the "quick start" guide of this device which does not have all technical infos.
Could you please point us to the technical manual of this device ?
Re: stream deck xl
Postby Niffo » 25 March 2024, 09:02
On MacOS they use "Companion". I don't know if it exists for Windows.
Re: stream deck xl
Postby SeekLighting » 25 March 2024, 09:29
Yes, Companion is available for Windows
You can use Companion to send MIDI commands from the StreamDeck XL to The Lighting Controller. I believe there are other users on this forum who are deploying this solution
Re: stream deck xl
Postby stef » 25 March 2024, 18:05
Oke. With Companion for windows it is possible to activate and deactivate with the stream deck xl the live buttons in Quick DMX if i understand it right?
How do it works?
stef
Re: stream deck xl
Postby stef » 29 March 2024, 13:51
I found the same, only quick manual
stef
Re: stream deck xl
Postby pogjack » 17 April 2024, 21:03
I’ve been using it for a year so far and it works. Only complaint and I’m not sure if it’s companion, showxpress, or the computer, but when I activate companion for showxpress my showxpress lags majorly. When I disable the companion just for showxpress it moves along just fine.
I’m using the Streamdeck + and have to use the midi plugin to control the master faders but it does work.
pogjack
Re: stream deck xl
Postby support » 19 April 2024, 09:04
Noted.
We will check that asap.
BTW, your profile says you are using Windows. If not, please let us know.
Return to Live - Buttons
