out of topic ! DMX 6 channel console issue
post here other topics
Postby Luc Henrion » 23 April 2017, 16:36
I know it has nothing to do with Sweetlight but maybe someone here could help anyway...
I came across a very, very strange issue: I own a little 6 channel DMX console that I use sometimes for very simple setups: just a few PC or Fresnel on a Dimmer bar for example.
And it works. No need for a computer in this case you'll admit.
But now I wanted to add a pair of brand new LED (60W) mini-profile (in 1 channel mode) and they simply don't respond to DMX. They DO, perfectly well, with my USB dongle and Sweetlight, they work just fine also with a simple 36 channel console, but they don't with the 6 channel... I tried everything: going thru a splitter/booster, changing the cables, putting a DMX terminator. No way. Any clue ???
Thank you all.
Luc Henrion
Re: out of topic ! DMX 6 channel console issue
Postby Lighter007 » 25 April 2017, 05:31
How many dmx channels does the led fixture use? Did you put it on adress 001?
Greetings from Germany! :)
Lighter007
Postby Luc Henrion » 25 April 2017, 08:44
It can be 1,2 or 3 channels, I put it on 1 ch mode, and tried DMX address 1, 2 and 3... Really strange since it works perfectly with my other console or the USB dongle. Are there some "variations" on the DMX standard ??? Some tolerances ?
Luc Henrion
Postby Lighter007 » 25 April 2017, 19:12
Maybe two pins are swapped/other harware issue?
Lighter007
Postby Luc Henrion » 26 April 2017, 07:22
No, I checked the polarity, it is the same everywhere...
I can't imagine another hardware issue... maybe insufficient current coming out of the little console? I suppose there is 6 volts, this is ez to check, but how can I check the current?
Luc Henrion
Return to Other
