Win 10 Latest Update and Drivers for Box
computer, driver, ...
Postby Pink LD » 26 September 2016, 06:45
UPDATE: See next comment for further information and possible solution.
I have a Win 10 64 bit machine with the old box hubs, ever since I did a clean install of Win 10 with the latest Anniversary update, 1607, I cannot get my box drivers to work. I can get them to work when I go thru the recovery options and boot in Disabling Signature Enforcement but once I exit and boot back into Windows proper, no dice. I had to run my show tonight in the disable driver signature mode because I could not get a normal Win login to recognise my box except to tell me that there was no digital signature. This is becoming maddening. Can you help Support?
Pink LD
Re: Win 10 Latest Update and Drivers for Box
Postby Pink LD » 26 September 2016, 08:36
I am using Win 10 Home 64 Bit
On a Lenovo B50-30 Touch
I finally got it, but it required me to disable in the BIOS/UEFI Secure Boot setting and then follow the following directions:
(THIS IS A PROCEDURE THAT IS AT YOUR OWN RISK. CONSIDER CAREFULLY IF YOU FULLY UNDERSTAND THE IMPLICATIONS MAKING THESE KIND OF CHANGES TO YOUR SYSTEM)
http://winaero.com/blog/disable-driver-signature-enforcement-permanently-in-windows-10/
You can try the link first, and if it works, fine. But it did not for me and based on the error message IT is why I concluded I needed to disable the Secure Boot setting.
Pink LD
Return to General hardware
